2005 SLK55
destined for the new C-class late 2007 MY. Will it be available on the SLK? The new frame is longer and wider- will it fit ours?
2005 SLK 55 AMG
I hate to tell you but I'm NOT at
192.160.95.28 like your display says. I am at 10.32.xx.yy.
SLK350
The IP address is correct for you on the internet, the 10. address is internal to you behind your Internet address.
I guess the 10. machine is on a network or behind a router.
10. addreses ( like 192.168. addresses ) are reserved for internal use and do not talk to the internet directly but go via routers and a registered address such as 192.160.95.28
Hope that makes sense [:)]
SLK 55 AMG
That script to find the IP can only provide the info it can read. A proper NAT setup will cause problems for it. Also, I'm using IE6, and the script tells me that I'm using Netscape 4. heh
Anyway...
Got any pics of the new engine, or other info?
