hey guys. I run in to a problem with my ce230. I had lost 1st and 2nd gear. any ideas where is a problem?
Plus whats the diference between other models. ( I mean numbers after 722.4...) is the gear ratio the same?
can it be that the onely diference is valve body? or how it is callibrated?
How many miles/kms on the transmission? Original factory installed transmission or replacement unit? And most importantly, what is the service history???
its original. have about 250k km. fluid and filter change every 30000km
full number 722.408.02
till the errorwas no symptoms. gear shift was soft on time and no problems. just one morning stoped to drive.
Based on the kms and the soft gear shift, your transmission has reached the end and needs to be rebuild.
These transmissions shift firm (but not hard) when in good condition.
ok
understood
but what about other model? with the same first numbers 722.4? can it fit?
I have one gearbox from e200. will it drive? interesting can I change it till I will restore my originall one.
