I own a 1966 250se with a automatic gearbox is it<br>typical of this gearbox to be a bit rough at lower<br>speeds as in gearchanges and then become smoother as<br>the speed increases?
Discussion Starter #2
<br>Dear Neil Tatt,<br>We know that problem because we have already had 250S and same problem the best easy solution ²s changing the automatic transmission with 115 or 116 280S/SE we can buy second hand or used for a cheapest prices and don't need to buy a new transmission or spend much money these type transmissions require no modification to motor connection only adaption to kickdown rod modification with acceleration pedal connection.<br>But While you are buying the transmission second hand dpn't forget to buy w²th power turbine(completly).<br>Don't worry W115/116 automatic transmission are the same with 250S <p><br>
