Automatic door closers 600 SEL
1960 Views 8 Replies 6 Participants Last post by  ranarana
A friend of mine has a 92 600 SEL and the automatic door closers have quit working all at the same time. We suspect a fuse or a breaker/overload somewhere but we can't find it. If anyone knows where it is located and what we are looking for we would be very grateful. I'm kinda jelous as I drive a 420SEL but I love it anyway.
Thanks, Rod.....
1 - 9 of 9 Posts
92 500SEL to 01 E320T current 2014 lexus LS460
Closing assist
Good news-bad news, the fuses for the system are in the trunk behind a little flap, I think it is #10. Anyway there is a layout on the cover, they are in the middle of the fuse panel. If nothing works, chances are the pump is fried, a very common issue on all the 140 series of cars. The pump also controls the trunk lid pull down, and sometimes the handle, unless the update has been done. The closing assist pump is located over the rear wheel, next to the gas tank. it is best accessed by removing the liners on the gas tank/package shelf and the drivers side rear wheel. The centers pullout of the rivets,then the body of the rivet (dont lose the parts)If you have a CD it is a little harder since you have to remove it. the bad news is the pump goes for 600/700 dollars. There are some rebuilts out there, but be carefull of deals on E-Bay. There are some intermittent pumps, if you pull the fuse it works for a while, but fails later. I heard of one person getting a defective pump, the seller swore it was working.
he dealer changed mine, but also took the time to check the lines to make sure that there were no leaks which would make the pump run longer or time out. There also were some defective pumps in the mid 90s that had a bad hose internally that could be replaced, see if you can hear any noise coming out of it, after removing and installing the fuse. There should be a whirring, and a hiss as it shuts down. This should keep you busy for a while!
93 600SEL 91 420SEL
It is fuse #9. Remove the fuse and wait a couple of minutes. Reinstall the fuse. This should/may reset the pump. If this doesn't work, it's probably time to open the pocketbook.
I did this on mine in July and it has been working fine ever since.
Today after having my rear window mechanism changed,i noticed that my rear door was not self closing..on investigating further i noticed that all the doors plus boot lid is not self closing.I have tried taking the fuse out for few minutes and placing back ..doors works once and then stop working again.
Please advise ..
Any suggestion will be appreciated..
If the pump is gone how much it will cost????
Alan
$575-$749, depending on your "stealer" 2hrs shop time to replace. You can do that by yourself, unless you are not handy. Search on "closing assist pump" way back smack over driver rear wheel.
May very well be a closing assist pump. But i would have the dealer/mechanic look at it.. If there is a bad vacuum leak in the system.. Even if you reset the pump it will only work once or twice and then automatically shut itself down.
CL500, S420, 380SL
I had the same problem on my 96 S420 and finally replaced the pump. I actually bought 2 pumps and still have one of them. If you're still interested and the pump fits your car (call the dealer and find out) let me know. I'll give it to you for a reasonable price.
1 - 9 of 9 Posts
