1 - 13 of 13 Posts
Hi,i have a problem with the system because the headlights will not level themselves
Sensor,control module and motors are all good because the mechanic was able to move them from the computer when he scanned the car
Right now they r off preaty bad so is it because of that that they r not working?
I will try to level them but i want to know if there is something else to pay attention at?
What you describe sounds like improperly aimed headlights. For lack of the correct technical speak, the auto level feature levels the headlight based on how much sag is detected. For example, you put a ton of bricks in the truck, it sags and the system will adjust the headlights accordingly. It does not correct for badly aimed headlights. You still have to aim them properly.
My impression was that when i start the car headlights go up and when u stop they park down as my buddys x5 lights do
Is this not the case?
Hello
Can some please point me to the location of the rear Headlight range sensor for 2002 ml55. I bought the car used without this part I and have already bought a replacement. I would like to install it myself. Any help would greatly appreciated
Hello
Check the location just ahead of the right rear axle shaft.
That's where it's located on our neighbors w210.
As well, have you checked the headlight motors themself?
You have a swirvel sensor on the back, near axle, and near the front axel. Why dont you first try and disconnect one, move it up and down whilst the car is on / lights on and see if the headlights move ?
If yes, then you can manually adust the aim by using an allen key and adjust on the headlight. If not, then the sensors arent working.
SBK
Hello
Here are the locations.
It's been ~7 years since the original post to this thread, and I just realized that the OP's question was never answered after Lord Braska totally hijacked the OP's post. Adika, if you are still on the forum, did you ever get the headlights properly set?
1 - 13 of 13 Posts
About this Discussion
6 Participants
Darkmann
Mercedes-Benz Forum
Full Forum Listing
