21 - 40 of 40 Posts
Discussion Starter #21
iv got a merc man comin to have a look and put it on diagnostic machine
is the box you have th zf 4hp
W202 230k
I'm not sure it's the part Number is 6382701100 is that ZF 4HP stamped on the box? I can have a look as its in the back of my bus now.
W202 230k
Couldn't see a sticker but didn't want to roll it over in the van incase any oil leaked.. Rang Merc main dealer parts and they cross reffed my reg with the box part number all good :) Probably worth a phone call to them if I was you.. :) They said the ZF number is the manufacturers ref :)
hi muz, I needed a automatic v220 gearbox asap my number is 07908920049 can come today
nissan note
@jackbee I think it's best you take it into a garage. I had a very similar problem, when my gear box crashed I took my car into a local garage near me. The Automatic Man based in Acton, London did a great job at a very competitive price! They had me up and running very quickly and were able to offer advice and answer any questions I had for them. I highly recommend them to anybody with problems with automatic gearboxes.
Vito 114 tourer 2015: Vito 108d 97: 108d 98: Traveliner 2003 ; Aixam; z1100; xbr500; z440 ++++
NO
the main reason you find a lot of "traffic" on the problems is because MB (esp commercials) tend to last longer with very high mileages (400k miles is not uncommon) therefore more problems show up..... its called old age.
2000 Vito 110CDI (never should have sold it), Current project 1999 V220 Ambient
The auto box is not made by Benz. It is made by ZF Friedrichshafen who have been making automatic gearboxes for cars since 1965.
According to Wikipedia the exact same gearbox is used in the following cars
1995–2004 Peugeot 406 V6 3.0
1996– Mercedes-Benz Vito
1996– Mercedes-Benz V-Class
1997–2001 Citroën Xantia V6 3.0
1997–2001 Citroën XM V6 3.0
1997–1999 Peugeot 605 V6 3.0
1998–2002 Alfa Romeo 166 V6 2.5, V6 3.0
1998– Lancia Kappa, Phedra V6 3.0
1998– Renault Laguna 3.0
1998–2002 Renault Espace V6 3.0
1999–2000 Renault Safrane V6 3.0 24V
2001–2008 Citroën C5 V6 3.0
2004–2010 Peugeot 407 2.2i
2003–2006 Fiat Ducato 2.8 JTD(244 Baumuster)
Change og gearbox
Can anyone tell mé if i Can change my zf on my v220 2.2cdi from 1999 wirh model number 1019- 0000027 type 4 hp-20 and gmbh dB 638 270 10 00 wirh an other from a 110cdi wirh model number 1019- 000049 type 4hp-20 and gmbh dB 638 270 11 00 .. The danish merc dó not knowing if this Will work.. Somme mek's say that if all the nummers is not the same the Car Will not start or go into gear becurse the gearbox have a computer that has to fit.. So the Big qustion is is the cdi 112 and the cdi 110 and the v-clas's v220 the same gearbox..??
I am fairly sure that the gearbox is the same. The gear ratios are possibly different so the speedometer may not be accurate
Electronics
The spedo is one thing but what about the Electronics .. Will i nede to reprogrammering the ecu/main computer Unit or is the gearbox computer config the same.. I dont feal good buying a replase gear box and fittings it just to find out that the 2 dosent run on the same program.. Dó i make sense or am i Way of:D
C180 R/reg. Gear box problem auto
Please can any one help me , some coke got in my auto gear box,now it's stock in one gear, the gear stick moves to select positions normally but it doesn't change gears,reverse works,it's a mercdes c180 estate 1998.
I've a 2000 e320 with a auto box fault. I can drive about 4 miles with a faultless gearbox. Then the box will only stay in 1st for a while. Then the box gives up and only the revs increase with no movement. If I stop for 5 minutes the process repeats. Any ideas please ?
2004 vito 115 cdi
Need urgent help.
I have Mercedes Vito 2004 auto trans with 296k high km south Africa.
Van started viberation last month during early morning and very slight when going uphill. Went to local mech he told me to change engine and gear box mount. After changing all three mounts still has same problem, being told again to change propshaft done that still same. Mech said it could be drive shaft done still same problem. Got tired went to another mech got gear oil, filter and seal change still same.
Finally went to dealer for diagnose, they gave me a report stating torgue converter slipping. Went to gear box place repair converter still same. Went back to dealer they send me to there gear box independent workshop, they quoted big amount of money to recon the hole gearbox. I agreed that finally my van will be fix last monday they called me that They fix the van and took it for road test still the same.
I am very upset, from day first the van viberates in 2, 3, 4, 5 comes and goes as you press gas padel and when it comes to stop it wants to jump forward and cut the engine off.
Please advice.......
Mercedes Benz 190E - 1.8 YEAR 1991 {W201} REGISTERED NUMBER MAURITIUS (E 3)
Dear sammymk2 .never buy an automatic gearbox Mercedes ..when it is broken .nobody can repair it ..the last think you can do ..breaker yards ,,,, good chance ....
Vito W639 111CDI
Hello fred 22966,
I have the same problem with my vito gearbox, did you solve the problem ? How ?
Thank you from Spain
Hi everyone,
I have an 1998 Benz Vito 113 petrol, and have transmission problem. Does any one know if this model comes with the conductor plate with the solenoids in the transmission valve plate?
Here is some useless info on the gearbox maker they made the transmission units for the heavy german ww2 tanks Tiger 1/2 and Panther. They had problems only because it was speced for 35/40 ton and used in 45/60 ton tanks ,some are still functioning today.
21 - 40 of 40 Posts
