1 - 20 of 40 Posts
hi new member just bought a v220 with gearbox fault it will go into gear for a min or two then goes into neutral and nothing other times wont go in gear guy i got it from says it will drive for ten mins said he changed oil but not the filter
any help much appreciated
thanks
v220 ambiente
Hi
There are a number of threads on auto box problems, you will find them by doing a search.
Check the electrical plug connections.
Best of luck
G
Vito 114 tourer 2015: Vito 108d 97: 108d 98: Traveliner 2003 ; Aixam; z1100; xbr500; z440 ++++
as well as wiring problems, have you checked the fluid level?
ONLY mb auto GEARBOX (not ATF) fluid can be used or DexRon 3 or 4....... MB is preferred.......... any lowness or overfilling or wrong fluid has been known to cause problems.
if all is ok, come back and someone will post more info.......... quote the vin number for mb pdf info.
malcolm
v220 ambiente
Hi
I am trepidatious in crossing swords with malcolm, but as I understand things, having looked into autobox probs and ZF specs, Dexron oil is not suitable for these zf gearboxes. The requirement is very specific and you should get the correct part number from Merc or from another manufacturer who used these gearboxes (e.g. they were fitted to bigger Citroens). But make sure you are buying oil for this type of gearbox.
Using the wrong oil is disastrous, will wreck the box.
There are quite a lot of posts on this topic.
G
NEVER be afraid of correcting anybody if you have something to say...... I am no expert, just someone who does his own work (called poverty and a very small disability pension) has done a lot in his life and who collects information.
I agree with your comments on the gearbox and the need for the best fluids...... mb spec ONLY their Auto Fluid for the gearbox in the UK however they spec DexRon 3 (DexRon 4 is higher spec) in other markets e.g the USA for the same gearboxes.
The only differences I can find (and I am happy to be corrected) is that these other markets are either more remote with poor supply chains or have laws (as in parts of USA) that ban the exclusive supply and specification of their own products / spares / service parts.
As I have said before "you pays yer money and you makes yer choices" with apologies to john wayne and popeye.
Me...... I tend not to use merc fluids on cost basis and I do NOT drive an automatic (I don't like them)
malcolm
remember this is a discussion forum and not a dictatorship.......... keep putting your point of view.
YES
preferably use mb fluid... its best to give your vin and then ask for what you want..........
it is always unwise to change oils etc without changing any associated filter(s)
if you post your vin I will post relevant pdfs
malcolm
2015 116 Long,2007 115 Sport,2000 Vito 112CDI Auto,85 Escort Cab,81 Escort 3dr Estate,87 Escort RST
If its the ZF-4HP20 gearbox you will have to split the box in half to replace the filter.
There should be a plate on the top of the box.
I will try to get a pic of mine and post it for you so you know what to look for.
2016 Vito 116 Bluetec
I just recently had to replace my gearbox, as it stopped altogether....
It wouldn't select any gear.
Have you put it on the computer to see if there are any codes coming up ?
Might be worth seeing a transmission workshop, but find on that knows these vehicles... a lot of people seem to know very little about them :(
Here you go, sorry for the delay.
I have added some pics of the filter you will need if your box is a ZF 4HP-20, it cost about £35 from the MB dealer.
1 - 20 of 40 Posts
