Hi, I have 2001 E320 CDI, just changed the battery and i put in the code but as soon as i finish entering the code the radio displays "Phone" and stays there, no matter what i press it does not go away:mad:, the audio thinks the phone is being used and is muted. but i have no phone connected and I have tried discconecting the radio/battery but still no luck. I have the right code as it goes into phone mode. The problem is bringing it back to normal mode so i can use it.
Can anyone help please? :confused:
its Audio 30 :
The phone mute line is pulled down "by someone". Check it, you can disconnect it temporarily if necessary.
Where are you? Do you have a phone kit or Tele-Aid in the car?
