SL320 R129
Guys, I removed my Audio 10 radio/cassette in my 2000 CLK 430 and put in an Audio 30 navigation unit. The install was fine and all fuctions work. However, I thought that I could get the direction arrows to appear on the in dash screen!
Anyone have the above unit in a CLK? Can you help me out?
Thanks.
ML500
The cluster needs to be told the nav unit is present (in order to enable the nav screen ...
The cluster needs to be told the nav unit is present (in order to enable the nav screen in the cluster) - dealer has to do this using Star Diagnosis
You should get the Audio-30 APS correctly coded to the car type / speaker config / steering wheel side whilst they are doing that ..
Cheers
R
SL320 R129
Thnaks for the info Richard.
Seems obvious when you know [:D]
Jonathan...
Jonathan
