Last night someone attempted to steal my 1987 190 2.6 right from my driveway, i thought it was my neighbors getting home so i never looked when the dog barked, They were clearly stupid to think that you can just pop the ignition in a Benz,,, they must have found out that they needed to do more than just stick a screw driver in the ignition, Well in the process of them attempting this they damaged the inside of the ignition lock column (tumbler),,, i can get a new one for $67 no problem right? Wrong! In order to get the old tumbler out the key has to be in the on position to use the Mercedes tool to release the lock column. My key will not turn at all due to the damage done to the inside components of the lock column. Has anyone ever been in any type fo situation like this? Mercedes said its a $120 job parts and labor if i can get the key to the on position, if not it will cost in excess of $600 because they have to remove the dash and grind the old ignition out. Is there anyway to release the ignition so i can atleast get it to the on position??? Someone Help,,, They want $$ i have 0
