First off kudos to Atmshmr for your in depth DIYs overall and these brake specific ones:
Pads:
http://www.benzworld.org/forums/w220-s-class/1517669-changing-brake-pads.html
Fluid Flush:
http://www.benzworld.org/forums/w220-s-class/1609519-diy-brake-fluid-flush.html
I've done brakes on bikes and other cars, but not on M-B or anything with wear sensors. So it's nice to read through and see that things are generally the same. I'm not usually one to go for the uprated fancy DOT4 fluids, but I do like the idea of contrasting color to more easily see the new stuff at the caliper. Just a note, I've seen friends use the blue on bikes, and the dye fades in sunlight. Most sporty bikes have opaque reservoirs and sometimes clear lines to the master cylinder if retrofitted with upgraded brakes. Not that it matters here, just thought I'd mention it!
In any case, since you first posted the pad change have you needed to replace the rotors? If so, what brand did you use?
Any further notes on Akebono pads?
I'm slowly preparing to service my brakes in late spring/early summer. Got plenty of pad left, but some ugly scoring and definitive lip on the front rotors. Plus no service history, so better flush the fluid while I'm at it. Might get some flexible lines to be sure. Probably start buying stuff a bit at a time, so it's not a big bill all at once!
Pads:
Fluid Flush:
