1995 E320 1974 280C
On a 95 M104 with a 4 speed...How much ATF fluid (in Quantity) would normally be in the transmission Unit itself Vs the Torque Converter?
2008 E350 4M, 2016 Audi Allroad, 2019 Audi Q5
3 quarts I believe in the TC.
You must drain BOTH when doing a change. Otherwise it is almost worthless doing it at all.
1995 E320 1974 280C
Does anyone know off the top of their head the type and size of the socket required to drain the Torque Converter?
Thanks in advance.
W124 Moderator
The TQ pulg is the same as the transmission pan plug. 5mm allen I think.
Jayare
About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, 4Matics and 1 coupe
Don't forget to buy a new sealing washer for the drain plug.
