hi all!
As my title says, i just need to know what ATF and DIFFERENTIAL oil the Mercedes Owners Manual recommends to use for my brother`s late 1970`s (sorry, dont know the exact year) 280 SLC automatic, and how many liters or quarts do i need to do a fluid change for both? We are located in the tropics, so its very hot over here. Thanks!
patrick
1976 UK Delivered 450SLC
hi all!
patrick
Firstly does the car have an LSD diff? You need diferent oils/aditives depending on what you have.
Secondly for the auto will you be draining only the gearbox or go all the way and drain the torque converter as well?
1978 280slc
Transmission takes 7.2l if you can get all the stuff out. When I did mine, just over 5.5l came out. Use Dexron 3 or above and you should be fine.
The differential takes 1liter of 85w-90 or 90w. You might have to use 80w-90 though.
