1990 300CE
I ran a check with my code reader and determined the following faults. What do you guys know about the difficulty of dealing with these fault codes...or the parts needed to fix them? Can they be fixed on my own? Any input is appreciated.
SOCKET #3 = Fuel injection system
- Fault 11 (Air injection system, short or open circuit)
SOCKET #6 = Supplemental Restraint System
- Fault 3 (Driver airbag squib)
- Fault 8 (Voltage supply interrupted)
SOCKET #8 = Distributor Ignition
- Fault 17 (Crankshaft position sensor faulty)
The first thing to do is erase all the codes, drive it a while, check it again and see what comes back. Some of them may not come back in which case you don't worry about them. Are you having any operational problems?
1990 300CE
Seems to be starting fine. Idles fine. Shifts into 4th slightly clunky. I'll erase the codes and drive the car this evening to see what comes back.
