E 420, 97
I am getting flashing fuel reserve, ASR Skid control message, the gear kick very hard on low speed under 30 mph, but if I turn off the engine and start it again the message disappear and when disable the ASR (ASR Off) the car runs and shifts very smooth, the engine runs fine.
Using Carsoft I got these codes:
1747 Can from EGS control unit disturbed
C1022 Can communication with ME control unit
132 Communication with DME disturbed
If anyone has this problem please provide the fix for it
Thank you
Banned
1999 E300 TD
The traction system is another system that is very low voltage sensitive.
Do these issues occur on cold days, lights and heater on when lots of voltage is being used?? If so you may want to have your alternator/battery checked out.
Additionally C1022 the traction system module can't(faulty) communicate with engine control module. That's typically a cable/connector issue, but could also come about because of a voltage issue. FYI the CAN faults.
I would be interested in learning what you find!!
PS---What other modules produced the other faults???
E 420, 97
I am going to check the alternator output, it didn't seems like the battery is week, the engine starts on the first turn and we do have cold weather here the problem start when we had snow storm last week.
thank you for your input
