1998 SL500 with PANO
Now, according to a German Auto Shop, my ASR light (undesirable "limp mode")is due to a plug in module attached to the brake booster. $300.00 for diagnosis and repair, so am I stuck with it or should the place that did the brakes "hear" from me? I should add that, at first, the BSR/ASR combo lit up, then went away, THEN the ASR ! came on...
92 500 SL 52 MG TD
My 92 just started SLR lite and limp mode too. Front brake job too. I shut down and restart to clear it. But also my son was driving with the tire chain switch lite on. My mechanic says live with it.
2015 Jaguar XF R Sport Twin Turbo, 1992 500sl Pano, 1999 CBR 1100XX, Super BlackBird, Jaguar X Type
Easy for him to say live with it, I wouldn't be able to. You need to get the codes read off pin 14 with a cheap l.e.d. reader, this should help guide you in the direction of a possible fix. Also get another mechanic, it amazes me that some of these so called professionals overlook that the car is 20+ years old and as such suffers from bad connections and corrosion and jump straight in with an expensive module type fix. It may turn out expensive but often may not.
