1 - 9 of 9 Posts
Depends on the day!
because you're missing 4 cylinders;-)
No, but seriously, can you hear the ASR kicking in a cutting power?
Jonathan
Outstanding Contributor
2003 SL500, 2003 SL55, 2005 S55, (2) 1991 300SLs, 1994 E320 cabriolet
I think that switching the ASR off does not actually turn it off! What it does do is raise the threshold at which ASR affects control.
'96 sl500, 87 300td
Turning off the ASR removes the throtle control but does not turn off the brake control. That is how mine works.
Depends on the day!
Strange...I had a 96 SL600 for a while and laid down Big smokey burnouts w/ out the AST cutting in on the fun:-/ Perhaps you can find the fuse and/or relay it goes through and pull it. I'm not the biggest fan of gadgets that cut in on the fun.
Jonathan
Bobterry99 is correct. From the owner's manual: "A portion of the ASR system remains active, even with the switch in the OFF position. If one drive wheel loses traction and begins to spin, the brake is applied until the wheel regains sufficient traction. The traction control engages at vehicle speeds up to approximately 24 mph and switches off at 50 mph."
I read that in the manual. What does that mean? Does it mean that the ASR is off when I am driving down the highway at 90 mph?
VR43000, I'm not a tech and don't know about ASR. But interpreting the manual, I would say that switched OFF the ASR will engage if it detects wheelspin and the car is going 24 MPH or slower. Once engaged, it will remain so until traction has been regained or the car is exceeding 50 MPH. And like kn90d3 wrote, it won't affect the throttle and only affects brakes when it engages with the switch OFF.
1 - 9 of 9 Posts
