1998 Mercedes Benz E430
My E430 1998 have that ASR/BAS light on and no acceleration
If I replace the brake light switch will the acceleration be back on normal?
W163 and General Mercedes Host
My E430 1998 have that light on and no acceleration
Welcome Tony 373,
===>>> Update your user CP info....
click on your icon----> click on Account Settings---->
goto Account Details----> add vehicle details---->
ADD your make model YEAR ----> click save
CEL light on.
No idea if that will resolve your issue.
BLS is cheap so you can try that if you wish.
Recommend you scan and post any error codes here.
moving to w210 forum
Welcome Tony 373,
CEL light on.
I did update my profile
As I stated before, swap the BLS (brake light switch). Easy and cheap R&R.
Test and report back.
Also a possibly an ABS wheel sensor defect. If one wheel is perceived to be spinning at a very different rate than the other wheels, the ASR will back off on the throttle.
Scan and post codes.
Thanks for the reply and yes I ordered the BLS and once I get it and replace it will scan it and post codes
1998 E320 base sedan @ 160kmiles
A BLS will not likely affect acceleration. It is more likely a bad rear wheel speed sensor, or a bad ASR module. When wheel speed sensors at the rear different but plausible outputs (one different than the other), slips are detected by the ASR and you will have the flashing triangle on the dash. This is when the throttle is limited. The best way is to have the modules scanned with a proper scanner that can scan individual modules.
