97 Mercedes E420, 2000 Porsche Carrera Cabriolet
My 97 E420 is having a problem with the ASR/ABS light coming on. Brakes seem to be fine, and brake lights work too. Also cruise control is out. Anyone have a fix for this one? Again, the brake lights come on as pedal is pressed so I don't think we have a bad switch unless it's bad, but working as well.
Marc
The problem sounds so familiar. If I remember correctly, the brake switch should be renamed to brake switches because there are 2 contacts inside the casing to do 2 different things. If 1 particular contact is broken, you'll see "lamp failure" on the display.
2002 E320 210.065
The brake switch (located above the brake pedal) is the first place to look for the problem. It is a very frequent culprit.
Part number is 0015456409 and it lists for $20.
There have been reports of faulty aftermarket switches, so it is a good idea to replace with the OEM part.
