Linh and I did a pulley install on an automatic transmission car and it wasn't too much harder. To keep the motor from spinning there's a rubber plug under bell housing that you pull off, slip something thick in there to keep it from rotating and we were able to torque the pulley to 200 ft-lbs torque. If anyone needs a pulley install done in So Cal, Linh can do it for $50. His phone number is 619 972-4114.
Here's a pic of the hole. This is between the engine and tranmission so you'll have to remove the plastic belly pan behind the one for the engine to expose this.
