2013 ML350, 2004 ML350
after several trips, the suspension noise that the C has had is "gone" according to the Tech (soon to find out) and was solved with a new strut. What's taking sooooooo long is an ac part that is making funky noises... again... [:(]
MBENZ ML320, AUDI A4 SPORT, MBENZ C230K SS (current)
there lazy the dealer, they did the same thing with minds about my fuel injector.....
ok, it's back but the suspension noise is still there
I've posted previously that there is a clunking noise coming from the front suspension of the car and is isolated to the right front area.
this is what has been done
new right front strut assembly
new shock absorber
new bearing 203-320-02-73
rebound stop (noted but can't find if has been taken care of)
sway bar mount (same as above)
It has also been brought to their attention on 3 separate occasions...
I've also mentioned to the tech and sa what Drew had mentioned about the loose sway bar bushings...
oh well... another quest
[xx(][xx(]
what else is there???
the rebound stop and sway bar mount were also taken care of... what else is there??????
W211/W210 Estate /W209/W208
Re: what else is there???
I Had The Same Noise as You are talking about
On my Wifes C Coupe ..It was a Broken Right Front Sway bar link..Replaced..No More Noise
thanks mark
thanks mark... will have it checked
