ml 320 amg style 2001
Hi , tachometer is not correctly indicate, the arrow may do not return to the beginning and may stop in max rpm place. But engine is all ok . Some time tachometer is normall.
Thanks.
2000 ML430 SOLD, 2007 BMW 328i Coupe, 2014 BMW i3, 2019 Honda Odyssey
Have you opened up the cluster or taken it out lately to change a bulb?
Sent from my iPhone using Autoguide
Did you disconnect the battery before removing?
Reason I ask is it seems many people have problems with the tachometer after removing their clusters (usually the needle bounces quickly or won't move on startup). If this is the case, you may have to replace the cluster or learn to live with it.
It is clear. Thank. Is it possible to cure? Or only change? Strange it is random, some time all is good ,some time no.
