Having a hard time researching this online. have 4 ea 19" rims from '08 ML350 (tire size was 255/50R19). If I put 255/35R19 tires on them, will they fit my '08 E350 4matic sedan? Will I need some sort of spacer? Desperately seeking advice from those of you that know about these things.
You need to do your homework about the rims. Even the bolt spacing on MB is the same via many models, the rim width and ET vary quite a bit. Not to mention different tire height ratio that changed over the years.
I doubt ML wheels will fit on E even with smaller tires, but you are welcome to try. Report back ?
No, it didn't work
The rims were a little too wide. When mounted with 245/35R19's they scraped in the back. Oh well:)
