500 SE (1989), 304,000 km.
Hey folks,
Was just looking at the EPC (attached pic). I've just done a search on w/shields here, and there's no written mention of clips/screws/bolts relating to the w/shield.
  • Are there such fasteners for the w/shield, or are those only for the trim?
  • On this subject, re the trim parts, are those clips/screws, etc. typically rusted and should be replaced? (Are there any part numbers for such small things?)
Just checking from all you who've had your w/shields refreshed!
RS :thumbsup:
1985 500 SEC, 2005 E320
yes. Under the rubber on the right and left side of the windshield, are screws intho the window brackets (painted) trim. those get removed first before any other trim. . should be 4 or 5 on each side if memory serves. after unscrewing them they need to be slid upwards, toawrd the back of the car as they sit on a pin with a slotted hole. usually not rusted. however. unless you have a special tool to cut the budle tape, I wouldn't reccomend doing the windshield yourself. it's kinda like a 90 degree razor. impossible to do with a stardard box cutter or knife
