W124 Moderator
I don't believe so. My 90 300CE 24V. runs at a higher rpm at 80 than my 86 300E did. I am pretty sure you have different ratio's between the V8's and IL 6's.
But then again, this is a guess based on my own experience.
Good Luck,
Jayare
1976 BMW 2002. 1991 250TD. 1995 E320. 2018 Honda Africa Twin
the 260E and 300E had different rear end ratios. as did the 200E and 230E. as did all variants of the diesel cars, and the v8s.
coupes and tourings also had lower (higher numerically) ratios than sedans. want a drag car rear end? get the one from a 200TD or some such. might not handle a lot of power though, but on paper it should be the best for such an endevour.
the only commonality i know is when they switched to the 104 engine all the 6s used the same rear end ratio, same as the 300E. by that time mercedes was simplifying thier parts in response to the shellacking they were getting from lexus. of course the 104 engine was more flexible than the 103 with its variable intake, variable valve timing, coil on plug etc etc etc
85 300SD, 95 E320
is the original poster asking about the rear end (i.e. bumper) or rear end ratios?
i guess i'm interpreting the question differently - LOL
2001 SL500, 1995 E320 Estate
Who can help with valve timing while discussing differentials
Yes.
You - can use the search feature here.
You - can buy a service manual online.
Independent Mechanic near you - can do it.
Nice forum member - might offer advice, but try searching first, then starting your own thread.
