2006 e350
all my wheels are stuck
hello all,,, im new to mercedes. i just try'd to rotate my tires myself,, (the two fronts) i removed all the lugs and they still won't come off. :confused: should i force em off? and is this normal for MBs?
'07 GL320CDI
Make sure they're off the ground!
Use antiseize between wheel and hub; not so much that it spins onto brake rotors, of course.
2006 E320 CDI
Sit on the ground and kick the bottom of the tire with both feet. Should pop off.
07 E350
it happens, if kicking it from the front doesnt work, go ahead and put a lug on the wheel...not fully tighten but enough thread to stay on. Now from the back side of the wheel kick outwards and repeat. should loosen.
