Hell o,
My front original discs (300mm Diameter) are definitely vented discs as there was on the original two plates and a gap in the middle.
My rears which need to be replaced are 278mm originally and to my eye look vented in that there are two plates but a less obvious gap between. Anywhere I look for a pair of ATE brake discs in 278mm (or any other brand in 278mm) they are available in solid, which makes me wonder if, although my rear original discs look vented, are they?
Does anyone know if the original are classed as solid even though there is a bit of a gap between the two plates?
Thank you for listening,
Darragh
Darragh
