Oh...sorry to hear that you were not satified with the ride hieght. That's why i did my own.....
<br> I did pay to have my done too. But were also very disappointed with the ride hieght. So i decided to do it myself. I had to do it three time to finally happy with the ride hieght. The oringal pads that came with the car were, FRONT is #4 and REAR is #2. With the H&R spring, I replaced the FRONT pads with # 1 and the REAR with # 3 ( not #1 because the rear were lower then the front and my car were bottom out really bad so i have to put #3 pads to fix the problem).<br> Bib, if you want a little less stiffness in your spring. You should change the pads with the #1 pads. I know this for sure because i experiment with it already. Now, if you want less bouncing (bottom out) when your car hit the pot hole, then you should replace the shock with Bilsten sport shock.
