2004 SL55 AMG, 2006 E500
I posted on the R230 board with no input. It was suggested to check around the AMG group...
So, OP: It's time to change the engine mounts on the SL55 (again) and found the "Black Series" upgrades. I'm heavily leaning toward going this way, but wanted to hear other's experiences.
Also, if anyone has used other options (I've seen a couple of "performance" mounts online), please let me know of those experiences also. I don't think I'd go with a solid track style, as I think it would transfer too much vibration, but maybe I'm wrong.
2004 S55 , 2005 S55 , 2004 S430
I've have the black series mounts on my s55 for several years now of hard driving, and I would recommend no other mounts especially the transmission mount. The black series trans mount is significantly more robust. I was only getting about a year ,10k miles out of regular trans mounts before they sag and drop, causing driveline vibrations. And the motor mounts are not the easiest to change so do your self a favor and get the black
Thanks for the reply. I did replace the engine mounts with the black series. In big part, because the mounts on the SL55 are notoriously hard. I was going to have my indy do it, but when he quoted me $1k in labor, I decided that an afternoon of my time and gained knowledge was worth it. It was a complete PIA (the driver side). When I pulled the old one out, it fell into 3 pieces. Not good considering they were about 3 years old. So we'll see how these hold up.
I'm curious about the transmission mount. Everything I read kind of pointed to it being not worth the cost. It's interesting that you have a different opinion. If you can think of any details, please share. Is it just lasting that much longer?
2009 SLK55 AMG I 2010 ML350 2WD Base
I've had the BS mounts on 2 cars. Good upgrade.
If you want better, ECE was the go-to but since Ahmad folded up shop, I believe now Creative Steel is the only vendor for performance mounts. They've been around a long time.
Creative Steel
