1999 CLK430 Coupe
i got some brembo rotors that were cross drilled by a company on ebay. I have had no problems with them.
1999 CLK430 Coupe
i got just a front pair, they fit perfectly with the OEM caliper system.
190e 2.3l-16v
Some of the inexpensive Brembo rotors on Ebay you see are not "authorized" Brembo performance parts.
Here is original goods
http://www.brembo.com/ENG/Performance/SportBrakes/SportBrakes2.htm
Brembo supplies blank rotors and sells them worldwide. They are just OEM spec rotors. People get them and have someone with a drill press put holes in them and/or slot them. They are not to any specs.
Some factories in China make blank OE rotors and they even copy the Brembo boxes with logos. They get shipped in from overseas, purchased in bulk, and drilled out by 3rd parties. So who knows what you are really buying and where it actually originated from.
With respect to them looking cool, you may as well buy new factory Benz parts from dealership or buy actual real Brembo parts from an authorized Brembo reseller. (www.brembo.com you can see all the applications they provide and part numbers)
From my experience most Brembo OE size performance slotted rotors will cost about $200+ range per pair,
You can go to catalouge and see applications:
http://www.brembo.com/ENG/Performance/Catalogue/
Notice a lot of model applications we see on Ebay are not even listed in Brembo catalouge.
Just want to give a heads up for those who may not know. I was a victim of this sham myself before doing some research.
A.k.A Benzonlorinzo
Gorilla Beast - 3/25/2005 2:30 AM
True that.
But most people that buy these rotors on ebay are doing for 80% looks only . As long as of course there is some functionality .
Simply buying rotors that are OE brembos wont do ur braking perfomance any good .
You need the whole kit , 4 pistons calipers , brake lines even servo in some cases to get that porsche braking performance.
Unless u are will to spend 4k.
$200 ebay rotors and some caliper paint will be just fine . [:D]
