TVT Design, Crossfire Performance Parts - TVT 250
wondering if anyone is considering doing this. Don't know if it is legit.
No, its an underdrive pulley, 230 one is an overdrive.TVT Design, Crossfire Performance Parts - Light Weight Crank Pulley
is this similar to the ASP Racing pulley for the 230, and what kind of results could i expect on the 320?
simple solution to HP envy!i am looking very forward to 300 hp![]()
i would be in heaven with 280 even.
well... the ad in the link says Underdrive pulleyIt is not an underdrive pulley or an overdrive pulley. It is a lightweight crank pulley with the same dimensions as stock. They are produced by adedin motorsports.
Typical gains on a stock 3.2L are 10-12 HP.
You're missing the point, there is only one pulley, and it's the crank pulley.would you be able to put on the lightweight under drive pulley with the lightweight crank pulley? What gains could you see with both of them?
