I am considering increasing to a bigger rim size plus one or more. I would like to know what if any people's impressions are if any. What type of tires also. All applicable data would be greatly appreciated. No rubbing!!!!! And note if you have stock or eur or other suspension mods. thanks email me!!!!!!
: i have a 1999 c 43 with 18X8.5(front) 18X10(rear) 225 40 18(front) and 255 35 18(rear) with h&r springs. runs great<p>and they fit those rims are monsters big footprint did you roll the fenders or modify the inside wheelwells? what size spacers are you using?<br>Are you sure about the wheel size sounds wrong for the tire size stock is 7.5 & 8.5 if I am not mistaken and 225/45/17 245/40/17 thanks spr
18x8(front) 18x10 (rear) lowered and everything.<br>225 40 18 and 255 35 18. no rubbing or anything.<br>dont belive me come to autoclass in miami and they will show you many..<p>
Discussion Starter · #5 ·
Sounds like the 18" SL 2-piece setup...
I love those rims. Yes, those rims can be fit onto a C-class (or SLK or SLK for that matter), but they require extensive modifications for proper fit.
Discussion Starter · #6 ·
: 18x8(front) 18x10 (rear) lowered and everything.<br>225 40 18 and 255 35 18. no rubbing or anything.<br>dont belive me come to autoclass in miami and they will show you many..<p><p>just would seem like the rims in the back are a bit big for such a small tire I am used to hearing about e55 with 9" in back w 255. any problems or anything? What did you get them off of? are you running stock offset? 30, 35mm?
