1 - 12 of 12 Posts
Someone knows something about installing the V8 engine in a 5000 Mercedes W124 coupe. I would like to get into this adventure with my 300 ce 24v.
thanks.
W124 was the internal chassis-designation for the 1985 to 1995 version of the Mercedes-Benz E-Class. The W124 models replaced the W123 models after 1985 and were superseded by the W210 E-Class after 1995. I am sorry dude I do not have much information about this car.
300CE-24, W204 C220 CDI, W210 E55 AMG, W124 300TE, W163 ML270 CDI
It can and has been done, its actually easier than most swaps. I'm sure I've seen posts regarding this, there's plenty of guys doing it. I mean, your going to need money to do it, and probably relocate the battery to the boot to accomodate the motor.
That's the post I had seen. Thanks for linking it by the way. But no, Its quite easy compared to other engine swaps.
But I could be wrong again, from my experience this is so. My mechanic did an engine swap, except to save for the electronic gremlins, took the V8 from an old SEL and put it into a CE, made a huge difference visually and the sound was just sublime.
You would need to get new engine mounts to say the least, but as far as the gearbox goes, its a clean fit, if not slightly tighter. The engine compartment MAY need to be modified. Thing is, if your going to do an engine conversion, you may as well put in a 5 speed gear box, and a new diff to run at better RPM's.
Anyone could elaborate a bit more, I'm no professional :)
2008 E350 4M, 2016 Audi Allroad, 2019 Audi Q5
:confused:......:dunno:
It is going to require you to reshape the opening of the transmission tunnel and relocate a whole bunch of items.
Wanting to do this is SWEET, but be prepared for some intense work.
That's not necessarily true, The link above says you wouldn't have to for either case (400 or the 500 V8)
They still fit, but were tighter...hmmm?:rolleyes:
W124 Moderator
Dimentional size of M119 4L/4.2L and M119 5.0L are the same. It can be done, it isn't easy and money had not better be a object.
Good Luck,
Jayare
Thank you all for your comments.
I found V8 OSIRIS is a forum member mercedes190.co.uk
He has performed the transplant. I have sent a message to talk to him, because I think he does professionally.
I will tell you about
99-C43, 05-G55K, 71-280SL, 94-E320 CAB
Don't kid yourself....
Engine bay changes have to be made....
Just look at what was done for the "Hammer" installs...
You will see differences in the bulkhead and transmission tunnel areas in the engine bay in any production W124 V8 It's not an easy swap...
Just start with the battery location...I6 in engine bay, V8 in trunk...
First decision is what V8 to use...
Makes a major difference in the electronic interface...
Below pic is a V8 install done by AMG Central in 1989..
Note how the bulkhead has been cutout..
Yeah, thanks for enlightening me. But I hope you didn't take it the wrong way. Its still hard but from what I've heard/learnt/read its supposedly easier than most engine conversions.
What would you say?
1 - 12 of 12 Posts
