MOPF1 500E
Mine rounded off when trying to remove it (even w/ a flare nut wrench), and a new one is $43. Surely there must be a generic equivalent one can use after I get this out. Thanks.
Electrical wiring Gas Wood Auto part Machine
Hand Hood Automotive tire Motor vehicle Finger
Motor vehicle Gas Automotive exterior Font Bumper
Gesture Gas Wood Metal Jewellery
Rectangle Font Parallel Screenshot Diagram
· W163 and General M Gremlin
good Q.
bleed screw/valve on the ABS side?
M8x1.25 OR
M10x1.0 ?
Reactions: jlaa
That is not a generic brake bleeder screw. The $43 is trivial, but the trick will be to get the old one out.
My suggestion is to get a can of PB blaster or Bulldog and apply several times over a 72 hour period.
And then use a sacrifical socket to weld onto the rounded bleeder screw.
use a inductive heating coil to heat up the area around the bolt, but not the bolt itself.
Then remove using a ratchet.
MOPF1 500E
Thanks. Don't these induction coil things heat the bolt and not the area around the bolt (opposite what you suggest)?
The idea is to make the ABS block expand since it is made from aluminum. Aluminum expands quicker than a steel bolt.
The expansion will cause the galvanic corrosion on the threads of the bolt to let loose.
One more thing, before welding on a vehicle make sure you disconnect and remove the battery.
Otherwise you are likely to cause a host of electrical issues and/or vehicle damage.
