1989 300 SEL
1989 300 SEL I need to get this off to remove shroud to replace tensioner pully assembly. Any tips / tricks would be appreciated. :)
1968 gto (sold) , 91 volvo 740, 89 $300TE, 89 560SEC
When facing the engine, about 1-2 o'clock there is a small hole in the fan bearing assy. I slip a small pin punch in to lock the assy. down. Then you can loosen the hex (6mm iirc) bolt retaining the fan/clutch assy.
from small to large
while belt is still on, loose the center bolt. If you have removed the belt already, you would have to follow what p7fan described. Basically, once the center bolt is loose, rest is easy.
1987 W124 AMG 3.2 73kMiles (5 Speed) 1981 240D 4speed 400Kmiles 1989 300SEL 225Kmiles
having same problem. I took off the belt before removing the fan clutch and now it just spinns. I have looked for the small hole to lock the bearing/pully down but i cant find it. could you describe where it is in detail or show a picture
