1 - 9 of 9 Posts
1985 500 SEC EURO AMG/LORINSER; 1988 560SEL, 1995 S500 Sonderschutz
In my accident I broke both of the ends of the snorkels from the air box. I haven't been able to find any locally. Does anyone have a pair of these hoses or just the vacuum looking ends? Thanks a lot.
Always Remembered RIP
1991 560SEC AMG
I think I have one of them (for the right side, the battery side of the car I mean) in the garage at home, but I am still with this girl down in LA and won't be back home for a couple more days
(But if you want a clean one for free, just pm me your address and I will shoot it over to you when I get back home)
I am sorry I don't have one for the other side though for you..
That's awesome, thanks so much!
How critical are these snorkels to the performance of the engine anyway? Does much engineering go into them to produce "optimal airflow"? Or is it simply just necessary to "get some air in there?"
1982 380SE AMG euro(parted out),1983 300SD "Good Girl", 1984 500SEL AMG euro "Bad Girl"
It's one of those matters where every little bit counts. The snorkels get cooler, denser air from the front of the radiator with a little bit of positive pressure to help feed the engine. It'll run just fine but you'll see a performance loss to who nows what percent or fraction there of.
Discussion Starter · #5 ·
I have noticed a lot worse fuel economy. Could this be a symptom of poor air supply?
'82 Euro 500SEL, '85 Euro 500SEC AMG WB Cabriolet,'86 Euro 500SEC RUF
I'm confused. (Again! LOL!) Did you break the hoses or the snorkel tube ends on the aircleaner assy?
or did you break the inlet pieces on either side of the radiator? The tubes are easily come by in JY's that wreck Mb's. I may have an extra smaller(driver's side) one. Possibly a right side tube also.
If the engine is pulling in hot air as opposed to the normal cooler air that could be a result but I can't say to what degree. The older fuel system sense flow but not mass of the air.
Discussion Starter · #8 ·
I broke just the inlet pieces on either side of the radiator. The driver's side tube is fine, but the passenger side tube was crunched a little.
The 420 SEL at the junkyard was already missing it's hoses.
1995 E320 (totalled) 91 420SEL W126 (retired) 2002 S500 W220(retired); 2008 C300 Sport W204
1 - 9 of 9 Posts
