83 300TD/97 E320/98 SL500
I've been trying to figure this one out for some time now- After long freeway drives, when I come to a stop, the car idles a lot rougher than normal. Has anyone ever encountered this?
1983 300Dturbodiesel
mine sort of does that, how many rpm is the engine gogin when you notice it being jumpy?...
It is usually around 700- it's not noticably low, although I'm not sure how much differenc...
It is usually around 700- it's not noticably low, although I'm not sure how much difference a small change in RPM can affect the feel. Is this a sign of needing to readjust idle speed?
300 TD running rough
I've been experiencing similar problems w/my 83' 300 TD -- especially noticed after going over rough roads. The sounds are particularly rough from the back wagon areas!
Have you had any resolution??
