1 - 1 of 1 Posts
2011 GLK,2007 S550,2003 S55,2008 CLK,2009 C300,1996 E300,2005 E320,2002 E3
I am going to pick up a 1978 450SLC. The front end has to much play in it for me to dolly it with the front on the ground. I am going to pull it with the rear tires on the ground. I am going to unhook the driveshaft from the rear flex disk and secure the shaft. I am assuming that the rear flex disk is as accessible as it is on my 126, and 123 Euro. If any of you have been under your 107, let me know if this is the case. All I needed on my 123 was a 17mm 6pt for the nut, and a 15mm rachet for the bolts. It came loose very easily.
1 - 1 of 1 Posts
