2002 SLK 32 AMG
Speaking of front grills...I tried to remove mine yesterday and could not get the clips at the bottom of the grill to release. I did a search and have seen it described as removing the 6 screws at the top of the grill and the clips at the bottom. Can someone describe to me how you get the clips at the bottom to release? It appeared like I should just push the bottom towards the rear of the car but it still wouldn't move/release. Thanks.
SLK 230
removing grille
Hi Falcon !
The clips are very tight, but will come loose. I use a screwdriver (or similar) to push the clips slightly away from the body. Must confess I was afraid that I would snap the plastic, but they did come loose with a bit of pressure.
Good luck
