1 - 20 of 21 Posts
1990 300SE, 1983 300D
Is there any way to get the park lights and fog lights to be on at the same time? It only works with the headlights (like you all know), but is there any way?
Super Moderator
89 Mercedes 300E, 91 Mercedes 300CE, 71 BMW turbo 2002, 73 BMW 2002tii, 85 BMW 635csi
Pull out on the switch when parklights are on.[:)]
Note,this is a blast to the past message from
April 15,2005
Noo! On the 123 (at least my two), that didn't work. You had to do something with the wiring to have the parking and fog lights on at the same time.
78' W123, 00' W163, 05' W211, 89' RRC
yeah, that definitely does not work on our cars, is there something special with your wiring, cause parking lights + pull = parking lights
Benzless for now...
Nutz, sorry but you're wrong this time bud. You have to remove the fuse panel and move the fog light circuit from the headlight fuse to the parking light fuse. This will not damage or put your wiring at risk, but you need to make sure you change the fuse to the proper size. I think this site has more detailed instructions.
http://boostnbenz.1baddsm.com/DIY/
Thanks, cause i have always wanted that look
Benzless for now...
Yeah, I'd like to do that to mine as well. I would like to be able to use my fog lights as daytime running lights.
Super Moderator
Hmmmm!That's odd because all of my MB's do it even
my 6.9 and 450SE with euro lights.Even my old
74 and 75 450SEL's with US lights do it too!
One click to the right on the rotary light switch and
pulling out does not allow this function?Thats weird!
But who knows,maybe they have all been modified to
these Alaskan winter conditions(20+ hours of dark)[xx(]
Benzless for now...
Nutz, are your cars U.S. or Euro spec? I think Euro models have the fog lights wired the good way.
Super Moderator
my 280E and 450SE are Euro and the rest are US.
2005 w203, 2013 Town & Country
My Euro Spec does it .... on click right, one pull out turns on front fogs, two pulls out turns on rear fog with front fogs...
My valance fogs are on a separate switch in the map holder....
Jake
haha, I did try it on my 280 (euro) and it worked and now im gonna do what nutz4benz did to my 240. its gonna be hot especially with white fogs
Super Moderator
Dieselburns - 9/8/2005 10:54 AM
In my honest opinion i think nutz4benz is lieing! I think he disconected the headlights to order to do that! But thats what i think![:I]
No,I did not disconnect my headlights and no I am not
lying ! If that's what you think,then that's what you think,point,blank,period!!!
1985 Euro 300TD Turbo, 1983 Euro 300TD turbo, 1979 Euro 240TD and 1981 300D converted to euro.
only euro model do the light trick...mine is us and doesnt do it ,my friends is euro and does it.
1984 300D (235,000 miles), 2001 E430 (78,100 miles)
I looked at rearranging the fuse panel, but decided that was too big a pain in the arse. I, therefore, chose to attack the light switch.
The normal wiring (US spec) of the light switch is that power comes into the switch at connection "30". When the headlights are turned on, power goes out of connection "56" and goes to the turn signal/dimmer switch. If on low-beam, the power then goes to fuses 11 & 13. 11 feeds back to light switch connection "NSE". If the light switch is pulled (for fogs), power comes out connection "N" and goes to the fog lights. Going to high-beams cuts power to fuse 11 and the fogs.
I took the somewhat less than elegant route of cutting the wire going into "NSE" and connecting it to a FUSED (since fuse 11 is now bypassed) hot (positive) feed. This provides fogs at any time. Even with the headlights off, you can pull the switch and use the fogs as passing flashers (they won't stay on, obviously).
Benzless for now...
I figured there was a way to change the wiring at the light switch, I actually went through the switch looking for a circuit I could attatch the fog lights to but couldn't find one. Just to be clear, did you say there is a circuit on the light switch that allows you do this? If so, could you please explain? Sorry, but I couldn't quite understand what you were saying in that last post.
1 - 20 of 21 Posts
