I have read the topic about the diagnostic but
Any here knows which year was the first for diagnostic connector on the R129?
Did they start in 1989 with the first R129 or when?
Do i have it on my 1992?
You should have the infamous 38 pin connection port under the hood (bonnet) on the Right hand side of the engine toward the rear. It should have a plastic cover over it.
Regards...BAMeyer
Administrator
With a '92 he'll probably have the 16 pin diagnostic socket, not the 38 pin version.
Shades....You have me stumped (jag forstar ikke) on the 16 pin as to what type tester you can use but stay tuned in because someone on this forum will surely be able to offer you some help soon I should think! regards----BAMeyer
Thanks for the help
I went out and had a look and it is a 16 pin connector.
Took this picture in the dark with my old phone and under is what it is
1 Ground
2 OBD:push -button for onboard Diagnostic(California only)
2 CIS-E:Continius Fuel injection system(CFI)
DM: Diagnostic Module- LED(California only)
4 EDS:Electronic diesel system
5 ASD:Automatic locking differential
4MATIC:Automatic-engaged four wheel drive
6 SRS/AB: Supplemental Restraint System/Air Bag
7 A/C:ir Condition(model 124)
RB:Roll Bar(Model 129)
8 DI: Distributor Ignition
HFM-SFI HFM Sequental multi-port Fuel Injection/Ignition System
PEC Pressurized engine control
9 RST:Roadster Soft Top(Model 129)
TN-signal(Gasoline)
11 ATA:Anti Theft Alarm System
12 IRCL:Infrared Remote Central Locking
13 ETC: Electronic automatic Transmission Control
14 EA:Electronic Accelerator(Model 124)
CC/ISC:Cruise Control/Idle Speed Control(Model 124)
ESCM:Engine System Control Module(MAS), (Model 129)
15 Not used
16 Voltage, Ignition ON(Circuit 15) (Not equipped on all models)
