Any Good references for Torque Spec on W140?
4390 4
I'm preparing to perform front suspension work on my w140. I'm however having trouble locating information about torque specs.
I subscribe to Alldata, but there are no torque specs for front suspension parts.
upper control arms
lower control arm
ball joint
etc.....
Is there a book or reference website with the information?
Thanks,
Russell
1997 S600 (sold)
Upper:
Position upper wishbone to frame, then tighten nuts to: 50 Nm
Loosen self locking nut (6e)
Adjust position of upper wishbone so that dimension A = 63 mm
Tighten self locking nut to: 120 Nm
Tighten self-locking nut, clamped joint of upper wishbones to steering knuckle to: 125 Nm
Lower:
Installation :
Install in reverse order, noting the following:
Replace self-locking bolts and nuts
Install eccentric screws from the front towards the back.
Tighten eccentric nuts and bolts only in ready-to-drive condition.
Perform chassis alignment check. See: Alignment\Service and Repair
Tighten eccentric nuts and bolts of lower wishbones in ready-to-drive condition to: 180 Nm
Tighten self-locking nut for fastening shock absorber to wishbone to: 100 Nm
Tighten self-locking nut, supporting joint to steering knuckle to: 140 Nm
Tighten self-locking nut, supporting joint to wishbone to: 100 Nm
Tighten locking screw of front brake disc to: 10 Nm
Brett
