1 - 8 of 8 Posts
99 White ML320, 13 Audi S5,84 300ZX Turbo, 03 Audi A4, 03 Audi TT, 65 Ford Galaxie Conv
My clock has been difficult to reset (won't always respond to the twist and rotate) and now will not reset at all. Anyone have any tricks to get it to reset?
1999 Ml430
just keep on trying, let it go a bit in and don't pull it out all the way... mine does the same and I fiddle around until I get it
2000 ML430 SOLD, 2007 BMW 328i Coupe, 2014 BMW i3, 2019 Honda Odyssey
Agreed. It can be very tricky and you have to get it juuuust right.
Sent from my iPhone using Autoguide
This is what I do. Pull knob out, rotate right or left, then while holding right or left push knob in towards dash slightly until you feel resistance. That always works for me in both my ML's.
Mike
All those tricks did not work. So, at high noon, I pulled the instrument cluster fuse, which apparently just does the lighting. Pulling the negative battery pole didn't work either. Does anyone know which or if the clock is on a fuse?
ML 270CDI 2002, BMW K1300S, VW POLO 1.9TDI
Mine is also a hit or miss affair.......i have to pull on the knob towards me quite firmly and then a hard twist left or right (hrs/mins)
1999 ML320
Can't get it to work myself, gets me pissed but my wife has figured it out so i leave it to the female touch.
I got lucky sitting at a stop light after my attempt to pull the fuse. I tried Mike's ML's technique of pushing slightly until it "engages" and bam, it left me reset the hour.
Thanks guys.
1 - 8 of 8 Posts
