I have a 1995 C220 that i want to do the coolant change.<br> <br> What coolant should I use?<br> Do you use tap water or distilled water to mix the antifreeze or flush?<br> How many bleeder valve are there on the engine?<br> <br> 1)Drain radiator and close bleeder valve<br> 2)Fill radiator with distilled water <br> 2)Set AC to High<br> 3)run engine till warm<br> 4)turn off engine<br> 5)Bleed radiator and close bleeder valve<br> 6)Mix 50/50 distilled water with coolant fill radiator<br> 7)Bleed coolant on engine for air pockets while engine is running.<br> 8)Recheck coolant level<br> <br> Are these procedure correct?<br>
Discussion Starter #2
MB antifreeze .
MB antifreeze protects all the components<br>
of your cooling system.Water pump,alum.<br>
and plastic.Read on for more interesting<br>
info.
