1 - 12 of 12 Posts
1985 Mercedes Benz 190e 2.3 8v, 5 speed
Anyone have a picture of how the antenna is installed? For some reason my antenna was removed, I purchased one off ebay, but am unsure of how to install it.
Discussion Starter · #2 ·
Just a note, the whole assembly, motor and mast was removed.
1986 190E 2.3-16, 1992 190E 2.3, 2015 GL350 BTC, and 2020 GLS450
Back in 2008 I restored a 16v. That's the car back in May, 2008 undergoing reassembly after paint.
The original motor and antenna mast were malfunctioning so I installed a new set.
It was a pain to wire the unit. We had to get the wire chart and assemble a snap connector to match the fitting on the motor. When we figured out how to do it, it worked. The problem was that the new motor did not need the antenna switch on the dashboard because it sensed the operation of the radio and worked automatically.
Look up the wiring chart for your year car and prepare a connector.
'87--190E 2.3-16v(being rebuilt), '99--C230 Kompressor
for installing the antenna, you have to remove the plastic lining in the trunk on the left hand side, make sure your cap is good (new one is about $5 at stealership) there is a very short ground that connects to the unit and the frame and 2 10mm attachment bolts. plug your connector and antenna wire up and your good to go...it's about a 30 minute job due to the lining removal and installlation
IR MODERATOR
1996 Volvo 855GLT, 1993 MB 190e 2.3 8v, 1998 Subaru Outback SUS, 1991 BMW 525, 1998 MB C230
there are 2 types af antenna pre and post facelift, the mounting styles are different too.
Discussion Starter · #6 ·
Its pre facelift. Ill take a picture of it and the trunk wall this afternoon. I feel like I am missing a bracket or something to hold it in.
IR MODERATOR
there should be a bracket on the bottom of it like in lomtevas' pics.
Discussion Starter · #8 ·
Alright, after looking at mine and looking at lomtevas' I'm definitely missing that bracket, and you can certainly see where the bracket mounts to the antenna.
The below picture is what I got from the ebay seller when my antenna shipped. and the previous owner apparently just tossed the antenna and bracket as my trunk is devoid of any antenna related items. Just the tip of the old antenna that was super glued on to seal the trunk.
IR MODERATOR
i may be able to get you the bracket.
Discussion Starter · #10 ·
That would be wonderful! If not even a part number would be great as I've yet to find it on any parts site.
junk yard for less then $5
IR MODERATOR
i got it.
1 - 12 of 12 Posts
