1 - 18 of 18 Posts
1997 S500V, 1999 S500 grand edition, 2006 s65 amg
Well i remember saying on the forum i will take photos while rebuilding it. also I bought a Hirschamnn 6000ke rebuild kit for $40 from a local parts store. i mentioned everything except the actual removal of the antenna and installation of the mast also for the disassembly look at the pics it would make sense.
there is 20 pics
Discussion Starter #2
part 2 also the pictures are number on the left top corner(just in case order gets mixed up by uploading)
i just posted this because places charge $125 to do this work which takes about 30minutes. i know it might be handy to someone. you can find rebuild kits for $40 and new mast for $20 and those companies that rebuild and throw an aftermarket mast charge $150. and you guys can do all of this for about $75(including rebuild kit, mast, grease, and plastidip) this one was a rebuild for my spare antenna, i did a few for friends and relatives. simple task as matter of fact i was smoking hookah and drinking beer(California is hot this time of year lol) while rebuilding the first one lol here is a pic of the grease, and the cause of the rebuild.
W140 Moderator
"CHRIS" Merc 92 600SEL / Sold > 93 600SE / 93 S500 / 89 560SEL / 413CDI / B180-CDI /A170-CDI
Nice one , i willl remember this one when i need a rebuild .My antenna mast is slightly bend from speed (wind) ,i might need a new one soon .
Thanks NHZ for the effort posting etc . :thumbsup:
I deleted the other message so you have everything in one line order & not split .Sry to butt in to quick,lol.
its all good lol oh yeah forgot to mention the upper seal good bad with age and water gets into the antenna and damages that little circuit board. how fast were you going for the antenna to bend? lol i have reached high speeds and never had an antenna mast bend
W140 Moderator
It's not so bend that she dosnt go up or down ,no , it's just slightly bend from over the years , i drive aprox a 1000km's at a normal speed of up & around 110 to 140km/h constant at night only once a year (all up about 2500km's aprox between destination & return to base ),so it must have some sort of impact on the antenna staying up , tomorowe i take a picture i show you .
ok and btw i am using the gear shifter chrome trim pic to get a company to see if they can produce one
W140 Moderator
If you need more pictures of that let me know . :thumbsup:
Banned
2008 C200K (W204) & 1998 SL500 (R129) Imperial Red
great DIY comrade! love threads like this :D
1995 S320 SWB, 1997 S420 LWB
You should have put a screw to join the two white plastic wheels because the little tab that holds them together tends to break and your automatic antenna will not work if it does. This tends to be a common problem.
Discussion Starter #11
i know but this was a new gear from hirschmann. if its broken you could also fix it with a screw. i just don't know which screw to use.
Timeship, see you yesterday, but you already knew that.
Excellent write up.
Moderator
M20
the repair kit is available from the dealer?? dammit I had to buy my kit from a hirshmann reseller in new york(? cant remember) for almost $80
good post
Discussion Starter #15
No a local shop had it in stock. Not dealer the dealer only sells mast and complete unit.
Call Mike at Rhinetrade in Santa Ana. I saw a box of antenna's when I was in their backroom last week.
If Mike dont have ot or cant get it, you dont need it.
1998 S600 LWB 2011 GLK 350 4matic 2013 Sprinter 2500
I've done the screw trick as well. A good sheet metal screw should work. Be sure to Dremel or nip any extra to keep the profile minimal.
1 - 18 of 18 Posts
