1998 c230
Picked up these wheels last night, just have questions about lug nuts, and if I will need different ones or run spacers. I currently have stock 15 inch rims on my 98 c230 now.
They are 17x7.5 non staggered 35 offset.
I pretty much stole the rims, I am having the rims refinished.
Thanks in advance
1994 C280 1996 C36 2002 ML500
These are the stock wheels that are on the car now, 15"
Your factory bolts will work perfectly. For the front you are all set with the ET35. The rear will be just fine but I'm sure you could space them out a little if you wanted.
1998 c230
Thanks for the info. Ive been doing a lot of research on the topic lately. I got the part number off the back of the wheel as 202 400 03 02, so I believe they came off of a C36, so I am assuming I should have no fitment issues.
I picked up the wheels on clist for 225 with tires. I am having the curb rash repaired and the wheels powder coated next week. The tire size is 215/45/17 which is the exact same height as the 205/60/15's that are currently on the car.
