1 - 13 of 13 Posts
Merc ML270 CDI '01 & Merc Vito 108D '99
Hi Guys
As some of you may know, i have some problems with my ML270, havent been able to source an ABS unit or an AAM, parts no's are below if anyone can help it would be greatly appreciated
AAM- 163 545 52 32
ABS - A163 431 07 12
Im also looking for the sensor that goes in the passenger seat for the airbag system, have no part no. for this tho
Cheers Guys
Mark
· Outstanding Contributor
2006 ML500 2002 ML320
The part number for the seat recognition sensor is 163 910 13 50. Of course you understand that this item has to be purchased new and the seat has to be taken apart to install it.
The part number that you have for the ABS unit does not show up as a valid part, but the correct part is 163 431 04 12 as shown below.
You can try calling this salvage yard in the U.K. and see what they have.
Roughly how much do the sensors fetch from a dealer?? the fitting i dont mind as i'm a mechanic myself so no problem there...on BMW motorbikes mind you but sure cant be a problem
Whats the details of the salvage yard?
Why has the sensor got to be bought new? cant be used 2nd hand??
found a new seat sensor for $250, the fact that my passenger seat is on the left hand side of my ML, will that make a difference to your ones on the right hand side???
I thought you were aware of the fact that the "sensor" is actually a pad/mat that is part of the seat cushion, as illustrated below.
If you didn't purchase it new, the only other alternative would be to find a seat in a salvage yard, buy it and dismantle it and install a used sensor in your seat, one that which you had no if it was working or not.
You haven't said where you found this sensor. If the sensor number corresponds to the M/B number then it shouldn't matter.
Discussion Starter · #7 ·
thanks, i searched the part no. you gave me, i cant access a european parts catalogue for mercedes over here so cant go off anything
Discussion Starter · #8 ·
Woohoo......Look what a mate of mine picked up in Romania :)
Anyone any advise on fitting one of these? gonna get cracking into this afternoon
Discussion Starter · #9 ·
Oh no....ABS unit replaced and still got the 3 lights on the dash, pretty sure i got all the air out of system??? will i need to get faults reset for lights to go out???
1999 ML320
I believe for those 3 warning lights, you should check your brake pedal switch, $12 at dealer, then reset the system by turning steering wheel from lock to lock (from far left to far right).
Bernard
Discussion Starter · #11 ·
Bernard
I had replaced this switch before i went looking for an ABS unit, so that was ruled out
1999 ML320
Did you also reset your steering angle sensor? There is also two other sensors associated with this system, yaw rate and lateral acceleration. Many people had the ABS pump replaced and spend a lot $$$$ just to find out later that it was actualy one of these two sensors going bad.
Discussion Starter · #13 ·
no i havent done anything with those sensors??? it had a "high pressure in front wheel circuit" fault so the ABS unit was faulty anyway
Just need to get it back onto a diagnostics machine again :crybaby2:
1 - 13 of 13 Posts
