sl320, 911C2
I have just bought my 94 SL320 at $15000. I am very satisfied with it except for some annoying sound when I drive with the hard top. That seems to be some grinding noise between the hard top and the car body/side window glass. Does anybody got similar problem? WHat can I do to reduce the noise? There is no such noise when i drive with my soft top.
Thanks!
Simon (HK)[:0][:0]
sl500
Thanks!
Simon (HK)[:0][:0]
Simon I have a '97 sl500, the manual mentions synchronizing power windows is the power has been interupted. It says press the up side" of the switch and hold it for an additional two seconds after the window is closed. Repeat procedure for each window. Tfhe automatic full opening and closing procedure of the windows should now be restoreed."
Might not help but shouldn't hurt.
Fred
mercedes 300 sl-24
hola, no hablo inglés, soy de Barcelona (SPAIN), COMO PODR�A SOLUCIONAR EL PROBLEMA QUE ...
hola, no hablo inglés, soy de Barcelona (SPAIN), COMO PODR�A SOLUCIONAR EL PROBLEMA QUE TENGO CON EL HARD.TOP, CUANDO CIRCULO CON ÉL, TAMBIÉN OIGO UNOS RUIDOS, QUE CUANDO BAJO DEL TODO EL CRISTAL, YA NO SE OYE.
GRACIAS Y PERDON.
00 S500,99 4wgn,87TD
Thanks!
Simon (HK)[:0][:0]
do not use wd-40 on any rubber item including seals around the top. use silicone spray or furniture polish. they won't ruin the rubber.....
