21 - 31 of 31 Posts
1992 500SL, 1999 CLK 320 conv, 2015 ML350, (2011 ML550 gone, C320 wagon gone, 2005 C240 gone)
Discussion Starter #21
I bought one off Amazon yesterday -- going to try and install this week. Will document it too.
Next is the illuminated door sills I want to retrofit too that I got from a pick n pull for $10 bucks! That's a tougher job though.
Next time, I'll do the opposite of an impulse buy, and wait for the right truck with all the options
Sent from my BlackBerry Key2 using Tapatalk
Are you going to do the install yourself? If yes let us know how the install goes.
2015 ML250 BluTec, 2002 ML 500 Sport Edition (Sold :(), 2012 C250
You liking it.
Eh. Was really a pain to configure, and I used to work in IT. There are a LOT of bugs. I have a lot of configuring to do now.
The physical install was easier than the electronic config which I never thought I would say
2000 ML55 sold😢 2013 ML500,😁 2015 C250 estate wagon, 1927 Dodge 4 sedan, 1929 Dodge
I’m absolutely hopeless at that sort of stuff I just don’t understand it. I might just leave that upgrade alone for a while I think. Looks good though.
current: 2014 ML350 Bluetec past: 2008 ML320 CDI 2007 R320 CDI/2005 E320 CDI
Thank you. I'm just so confused that I was getting audio (calls + bt streaming) thru the android side without running anything to the aux input, and then bt streaming stopped working. Calls still go, which is what befuddles me.
Inside setting there is setup where you define default way for running audio - BT/AUX. I assume for any reason, it reset to default (AUX). Before you change any setup, take picture due to you could end up in some limbo state.
As somebody said - installation is much easier that running configuration. The other day I left car on sun and once I turned device, it reset to default. I have to admit it does work faster after that but I needed to reinstall all applications.
As bottom line, device is nice but it does need constant maintenance :smile
Discussion Starter #27
It looks very nice but based on what I read here I am going to wait until they have more stable, less buggy system. Thanks for all the excellent inputs.
04 C320 Coupe
For you guys who installed this, does it auto-dim at night? Seems like it will be annoyingly bright if it doesn't dim itself.
04 C320 Coupe
The Android install? Already did it.
Hi. Could you link me to this exact model? The link earlier in this thread seems to be the 8.4" model which looks like it covers the vents a bit. Yours looks much cleaner.
8.4 Inch Round Corner Car Touch Screen, 4GB RAM 64GB ROM Blu-ray HD Car Radio Bluetooth GPS Navigation WiFi Head Unit Screen for Mercedes Benz M ML GL Class W166 X166 2012-2015 NTG4 https://www.amazon.com/dp/B07PBT7BLW/ref=cm_sw_r_cp_apa_i_kpPPDb2NBVC7Z
21 - 31 of 31 Posts
